If I understand this rightly, the standard way would be to lay 18mm ply first and then the new tiles with flexible grout. This means there will be quite a big step up into the bathroom, about an inch.
As an alternative could I remove the t&g flooring and replace it with a flatter surface? The ceiling is down underneath so I could also add some extra strengthening joists with no problem.
Many thanks for your suggestions.
JD
JD
