Hi everybody,
I need some help identifying where a leak comes from.
I have the following pipe
and I suspect its leaking from (at least) one of the three places I marked with the arrows.
My guess is from the top of this grey plastic "nut" because its wet there. However, when I tip that blue switch there is still some leaking which would indicate that perhaps its leaking from the copper "nut" at the bottom two.
Can someone give an idea how to identify where the leak comes from.
Also, the most important question is how do I fix this? I tried to tighten the copper "nut" but still leaking. So my next attempt will be to tighten the grey plastic "nut" at the top. But I am not sure what sort of tool I need to turn this. Any ideas?
If I find that no tightening will do any good, do you think that the rubber washers need replacement?
Thank you
Vasileios
Thank you
Vasileios
