Hi all
Just wondering if I could get some advice on a little issue I am having.
I discovered a pretty heavy leak coming from a pipe that leads from my cistern to the toilet pan. The pipe is PVC and has two fittings, one directly on the cistern and a joint slightly below. After doing a little troubleshooting, I can see the leak was from the lower joint. I tightened it as much as I could which has drastically improved the leak, but there is still a tiny bit of water coming out, like maybe one drip every hour.
Is it a case of tightening it even more or do I need some teflon tape or could the joint be broken altogether. I tried to do some googling on this type of joint but I cant find anything. I dont know its name or if it contains washers\seals of some kind.
Anyway, Ive attached a photo. Thanks in advance for any advice, even if its just the correct name for the joint
