Was having a ponder about decorating daughter playroom on Saturday, when I noticed that the radiator in there is quite rusty on the bottom edge.
So I decided to poke at it, as you do. Fingers behind the radiator, I can feel quite severe rusting there. Fingers come away damp, and I can smell the inhibitor I put in the system last month on them.
So, it's weeping..not gone, but going. Now, I'm not overly mobile at the moment, and stepladders/loft antics are a big no-chance. I can see how I'd go about changing this rad with the valves it has (manual), without a draindown of the system, but IDEALLY I'd like to get a TRV in there as well.
What options do I have? I assume it's either shut the mains water off under the sink, drain down as normal to save going in the loft, or...possibly pipe freezing? Is this any good?
Just seems a pity (and a waste) to dump the water in the system out, when the inhibitor is so fresh. Any suggestions anyone? Or even any rough ideas at pricing for a job like this? It's a small radiator.
For now, I've shut the heating off and it's hot water only to try and knock the pressure in the system down a bit, and the valve has been shut on that rad.
If I just went for a rad change, is there any reason why I couldn't just drill a hole in the knackered rad at the bottom to get the water out of it simply and with less mess than the whole "side nuts and towel" method?
