Hi
I have a leaking radiator. This is a radiator which was purchased and fitted by cowboy builders. I don't know what the quality is like. At first it was leaking at the pipe, so I put tape round it and stopped that leak. It is now leaking from the bottom of the radiator where the valve is screwed in. I have tried tape but it still leaks. It leaks when the pressure for the system is correct and the heating is off. When the heating is on the leak disappears.
Is it possible that there is a crack in the radiator? Do you think a new radiator is the answer. I have tried to cure this for over a year.
