Hi we have fitted a curved shower screen above our bath, fitted the seal and it seems to leak in the corner. No matter which way we cut the seal or get a different type of seal it still leaks. It seeps out where the hard plastic of the seal joins the metal bracket and where the rubber seal joins the corner of the glass. In the bottom image the seal is not fully pushed on to show where it leaks even when it Is pushed on all the way it can go. What will fix this issue ?
A better screen!
That gap is huge and that junction between post and seal is always going to be a weak spot...
I would call the suppliers and manufactures and complain... As long as you have fitted it to their specifications!
