Hi
Can anyone help......
I replaced the internal bits in the toilet with a fluid master flapper cause we are getting water leaking through the ceiling into our living room. Even after I've replaced the fittings negating the overflow pipe. I thought this had solved the problem but after 2days it has started coming through the ceiling again. I've turned the water inlet off at the toilet and it stopped straight away...Im new to owning a home and doing DIY...Any advice would be appreciated
