- Joined
- 27 Jan 2008
- Messages
- 23,781
- Reaction score
- 2,683
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I fitted a 5 lamp G9 lamp in wife's bedroom, she insisted she wanted G9 and salesman said you can use LED, also wanted to switch from bed side so used an Energenie Mihome wifi light switch and remote control.
First problem was it would not switch off, so just managed to get a load capacitor to fit inside the ceiling rose of the fitting, however then she noted a flicker which was annoying, one LED failed so as a temporary measure I fitted one quartz tungsten bulb, all seemed to work great, so thought buy a box of quartz bulbs and continue using one tungsten bulb.
As expected the second hand tungsten did not last long, however the odd thing is now it had blown still no flicker.
I would assume flicker causes because the switch needs to use some power to work, but you can hear the relay click when turned on/off and with flicker relay was not heard, so switch is not switching on/off, and not a dimmer it is simple on/off.
So may be cause for flicker connected to bulb not the switch? but they were flicking before quartz bulb fitted, and did not flicker when quartz bulb fitted even after it had blown, so what causes the flicker?
