I have two rooms with different LED lights which are on the same ring main power supply but controlled with different switches. Each LED light has the ability to change the brightness depending on how rapidly you switch on/off/on/off the light, so some sort of stepped/latched function. One of the lights intermittently doesn't switch on but the problem appears to be solved by switching on and off the light in the other room. This isn't a simple logic problem as most of the time the lights operate independently as you would expect and they worked fine before installing the LED lights.
The light that is acting odd also has a remote control, so has the ability to be controlled through some sort of radio signal and through blipping the switch.
At the moment my current thought is that there is some sort of spike or other interference sent around the ring main which creates a signal or a state to have the lights in an OFF setting. By flicking the other lights, this then pings another signal around and allows operation. Is this a reasonable idea?
If so, would a ferrite on the light's wires help?
Any other suggestions?
