Hi All, New to this so bear with me
ok, i am wanting to install led strip lights into my decking under the balustrades, i have a total of 40metres of SMD5050 300 leds per 5 metres, each 5 metres has a total output of 72watts.
I'm going to run them parallel, based one the below:
the transformer (A) will connect to the RGB Controller (B) then supply 3 strips of RGB LED lights, there will then be another 2 RGB amplifiers (C) which will each power 3 & 4 more strips each.
so my questions are:
(A) How much does the transformer power have to be
(B) What rating does the controller have to be
(C) what power do the amplifiers have to be
also i have RGB wire which is used to connect each LED in links, can this be used to run them parallel? & can the amplifiers be wired up to the one power source/transformer?
or if anyone has any better ideas then i'm all ears.
look forward to hearing form anyone who can help me.
Paul
Paul
