so what you going to use for your car headlightsAs far as I know, all incandescent lamps will be banned.
Bulbs greater than 100W have already started to be phased out. Next to be phased out will be the standard shaped bulbs (usually called A-shaped) that are used in most homes.
Type of light bulb Date participating retailers will stop selling them
75-100W A-shaped Jan 2009
60W A-shaped Jan 2010
40W A-shaped Jan 2011
60W golfball-shaped and candle-shaped Jan 2011
Theres a lot of crap LED ones around, there a re a few good ones but the are not cheap, for bright ones its still a bit chicken and egg, in that pepole need to buy them to get the price down and the price needs to come down for people to buy them.i put in a load of led ones, but the were s h i t so took them all out again and put halogen ones in instead.
again there are a lot of crap CFL's on the market, and some good ones.The CFL spots my mother has take 5 mins to warm up, so arent really up to quick bathroom usage..
so youve tried craply made/ designed LEDs, and craply made/ designed CFLs now your going to try craply made halogensI think we will be buying from china from now on, if that is the case.
my supplier said the legislation was to stop the production of incandescent bulbs in europe, nothing about the rest of the world.
ELV's aren't low energy lamps, just low voltage.
I want to see one of these in the flesh, but on paper they look very good:I think spot lights will have to get a damn site better, i put in a load of led ones, but the were s h i t so took them all out again and put halogen ones in instead.
Crap lamps - I've got CFLs which take less than 20s to reach full brightness.The CFL spots my mother has take 5 mins to warm up, so arent really up to quick bathroom usage..
TTC, you should read up on the difference between the Building Regulations and the Approved Documents.ncoups, you should read up on Building Regs Part L.
this considers that only lamps that have an efficacy of greater than 40 lumens per circuit-watt can be considered as 'low energy'.
Para 44 specifically states that GLS Tungsten lamps and Tungsten Halogen Lamps do not meet this requirement. It makes no reference to ELV lighting.
This is what the rule says:I know, but I think in the rule that says 25% of your lamps in a new install must be low energy
