have you altered any wiring in the fitting? has it always worked ok until recently? all i can think of is that the switch feed and return wires may have melted and shorted together or someone has put a nail through the switch wire while some work being done?
does this same switch operate a fan?
Apart from the tape, and the fact that there should be 3 earth wires joined together, that doesn't sound like a mess at all - it's what you'd expect.
A 4-terminal junction box would have been better than 4 bits of choc-block though.
But if that wiring is all sound, and there's no short between your switched live and permanent live then the fault lies elsewhere.
It can't be in the actual fitting - if those wires short then you have no lights on at all...
