- Joined
- 31 Dec 2003
- Messages
- 170
- Reaction score
- 1
- Country
Lighting Woodburner
I've recently moved from a house with a Jotul woodburner which was easy to light using newspaper and kindling. The stove had a traditional grate with an ashtray underneath so to get the fire going I would open the ashtray door slightly which would produce a great draft.
My new build house has a Parkray Aspect 5 which is constructed very differently it has a solid floor and walls of firebrick (looks like chipboard) and a vent that is operated with a pull/push lever. Because there's no ashtray there's no way to temporarily increase the draft significantly when trying to light the fire.
The instructions for lighting seem counter intuitive - put two large logs on the bottom then two layers of fire lighters and kindling on top - light and shut the door with the vent open. I don't like fire lighters so have substituted them with paper but the wretched fire seldom lights first time. The Parkray website says to start with paper and kindling and add logs once it's got going but that method is no better.
It's suggested that warming the chimney with a large taper may help but i think you'd need a huge taper held for ages to be effective.
Any tips for lighting the fire would be appreciated.
