I would like to plasterboard the whole lot out (up to the purlings ) so as to make it look like a decent room not just a storage black hole,although thats what it will be used for.My idea is to board to just behind the purlings then plasterboard down to the flooring from the purling after putting a stud section up.Also what gap would you suggest to leave around the edges when i put the roc wool insulation between the joists.Then plasterboard the rafters(even though theres no felt under the slates(would that be ok?).If it is ok would you suggest the alububble then foil backed plasterboard or just foil back plasterboard?Im a bit worried in case the roof leeks although its sound at the minute and has been for a good number of yearsThe roof would still breath would'nt it? as im not enclosing it all in,ie behind the purlings both rafter and joist will still be as they are now.Long winded sorry never tried this before ,but have done most of it in smaller degrees.Cheers aspley
