loft ventialtion, tile vents?
5 Sep 2007
Ayrshire
I recently got a new central heating fitted which in turn opened up some space in my loft that I use for my computers.
The main problem is the heat in the summer.
I'm looking for some ventilation ideas, I've seen vented tiles that have a ducting output fitted to them that I could fit an extractor fan too, I'm wondering would I be able to get them for my roof and how hard is it to fit.
here are some pictures as you can see the CH flue goes out of the roof, i'm looking for something similar.
View media item 425View media item 426
last pictures was taken from the velux window, was going to get a extractor fitted to the window but it is a bit to far away.
Rezarf
Look for a different solution. A vent or two is going to help move some air around, but not make the room cooler
Vents are not going to make much difference to the heat build up. You need to insulate - to keep the heat out, and if you can't fit a couple of rooflights, then you will most likely need to use a cooling fan or aircon
its has good insulate just now and I'm finishing of the rest just now.
I'm just wanting to keep the air moving with some good ventilation as I have several computers running so I was hoping to fit some sort of extraction system to take the hot air out and something to bring fresh air in.
I been onto screw fix and seen some vent systems for roofs.
Rezarf
