As title really when using the mixer tap for the bath everything is fine, however when trying to use the shower attachment attached to the taps you either get all hot (hot tap turned fully open and cold just slightly opened)or all cold (when the cold tap is opened up enough to bring the water temperature to a bearable level), once this fine line is passed it all goes very cold indeed. Is there a way of either decreasing the cold water pressure to match that of the hot or increasing the hot. Just to add to this one of the main reasons this problem exist is because for some strange reason all the cold water feeds in our house are direct from the mains.
Jeremy
Jeremy
