Our cold water tank in the loft has recently been run almost (if not completely) dry because our cold feed had to be turned off for a day. Since then the hot water pressure in the taps has significantly reduced. It's bearable in most taps but it has meant that the upstairs shower only works at bath level and not when mounted above head height. I'm wondering if this could be due to a partial blockage in the pipework between the tank and the hot water cylinder. Is this likely or is there some other explanation? There are no pumps in the system.
I have had a look in the tank itself and can see nothing blocking the outlets (of which there are 3)
I hope someone can advise on what's causing the problem and also to let me know how to resolve it.
Cheers
Ben
Cheers
Ben
