I've just replaced the tap in my Kitchen as the old one was past its use by date.
Anyway, I have low pressure from the hot water tap (it was like this with the old tap, too) and want to boost the pressure. I was told that I can boost the pressure using a shower pump; is this true? If so can someone recommend me a shower pump?
Extra Details
I live on the ground floor. The hot water is fed from a hot water cylinder on the ground. Another water tank is about 1m above the cylinder, which is where I presume the hot water is getting its force to come out of the tap in the kitchen.
The cold water is fed from the mains, hence the cold water pressure in the kitchen is excellent.
Im thinking of installing the pump underneath the kitchen sink.
Extra Details
