Hi, I have mixer taps on the bath and a hose attachment on them so I can shower but the pressure is very low when I turn it from bath to shower what could I do to improve it any suggestions please
Tully
if your hot water is from a storage cylinder , and a cold water storage tank in the loft feeding it ,that would be typical of a gravity fed plumbing system , which is quite low pressure. if your bathroom is upstairs and your shower head probably a couple of feet under the tank in the loft then the pressure will be very poor. in this scenario people fit a pump to boost the pressure to the shower.
