newboy said:You could go for a venturi shower -Trevi make a decent one.
The mains cold supply is used to spin a turbine to boost the hot water flow
flow rate on cold is less than a combi would put out on hot
bster said:Simon says...
correct me if i am wrong but thats impossible.
bster said:Back to original post, how about adding a second feed for cold water from tank (higher than the cylinder feed) so that you have tank fed balanced supplys, and then connect to a pump for the shower (if your tank is big enough).
bster said:sorry matey
whats an elison tank?
bster said:Is the tank seperate to the cylinder or rigidly fixed to it, what is the tank made out of?
I think i'm out of my depth now as i'm not sure what an elisson tank is
simon_d said:bster said:sorry matey
copper hot water tank. has a small tank on the side with the cold water in that then feeds to the hot water tank. could i take a feed from this, along with the hot, to the shower pump?
Spark123 said:I'm interested now, can you take a picture of this elison tank setup? Is it similar to a header tank?
