Hi - Our kitchen has sets of low voltage lights set into the ceiling. Problem is that one bank of 4 have started to switch off then come back on again after about 20 minutes. Any clues please or should I ditch them and replace with mains voltage lamps?
Sounds like the tranformer is on the blink - overheating, cutting out, cooling down, coming back on.
Overall I prefer mains halogens to ELV, but not everyone does. The biggest thing I would say is that at first you will notice that they aren't as white, but you should soon get used to them.
