Hi All,
Can anyone give any advice on my latest problem?
Part of my new extension has a sloping roof, this is to be insulated, between the 150mm rafters with 135mm celotex type solid foam insulation boards, then plasterboarded out. Due to the ceiling hight and slope I had hoped to instal a number of LV downlighters, probably 20w in the sloping ceiling. Can anyone advise on how I should route the cables? I understand that it is not good practice to bury them in the insulation material. Would it be acceptable to cut a channel in the insulation foam or would I be better installing some plastic trunking, also what size & type of cable should I use from tranformer to lamps? How much of a cut out in the foam should I allow round the lamp fittings - as you know they get pretty hot!
Thanks,
Chris
Thanks,
Chris
