I've got some low voltage lights coming from two separate transformers (2 sets of 3x20w @ 12v). Both sets are brand new and installed properly.
Both sets are controlled from the same switch, but recently one of the transformers has been playing up.
They both used to light instantly without fail when the switch was turned on. Now, when I turn on the power, set 1 lights up instantly as it should do, but set 2 doesn't come on for up to 30 seconds.
It does light up, eventually.
What on earth is causing a delay? It never used to do that!
If anyone can explain the cause I'd be greatful.
