Just had A Vaillant VIH GB 210 S unvented hot water storage cylinder installed to give us mains pressure hot water. When turning hot water on followed by cold water (on full) hot water totally dries up. Had the water board out who said I have 18 litres per minute coming out of tap at 3 bar. The instructions for cylinder state that there should be beteen 20 to 25 litres per minute with minimum of one bar. My in let pipe from the water board main in street is either 12.5mm or 15mm. If I lay a new pipe and increase the diameter to 25mm will I achieve a flow rate of over 20 litres per minute that will supply enough water to supply cold and hot tap simultaiously. Also if I installed the larger 25mm incoming pipe should both the cold and the hot take their supplies from the 25mm pipe?
