I hope someone will be able to help or point me in the right direction.
Our water supply to the block had to be switched off temporarily to facilitate some local works on Monday morning. Did not think much throughout the day until we experienced the water pressure was a little low after 12 midnight in the bathroom. Water would run a litlle, then dribble.
Was still a little low on Tuesday, but after work, found out that the water to the bathroom and toilet upstairs had low pressure. Again, if you left it long enough, water would run, but fade away within 30 - 60 seconds.
The kitchen mixer tap (cold) seems to be running as normal (the hot side of this mixer does not work by the way). The washing machine also seems to fill as normal. I believe this feeds off the mains like the kitchen tap.
The toilet downstairs has also started to fill slowly (I believe this is fed from the tank upstairs which feeds the water boiler, bathroom and toilet upstairs).
Does it sound like it's an internal air lock issue? What's the best way to resolve (considering the hot side of the kitchen mixer does not work)?
The water tank sounds like it's taking a long time to fill. This has been the case recently (probably not as slow?) but water ran fine, so left it. Before this, the tank refilled with the sound of gushing water!
Any advice would be greatly appreciated!
