Am I the only person on the planet having horrendous problems with Lytlec fire rated downlights? These sort of things:-
http://www.screwfix.com/p/lytlec-fi...-12v-low-volt-fire-rated-downlight-pk10/80008
I've installed loads of them - don't know if it's just a dodgy batch but after about 18 months a LOT are starting to fail. All installed to spec obviously.
The contacts in the ceramic bulb holder start to corrode for no apparent reason and eventually the light goes out. Sometimes unplugging and re-plugging the bulb will fix it but normally only short-term. I've seen some where the corrosion has caused bad contact and arcing and the wires in the teflon sleeves has turned black. Not good!
Next question, anyone know of a source for replacement ceramic bulb holders with the teflon sleeves?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Andy
Andy
