macerators
16 Dec 2008
Berkshire
the company i work for uses macerators to remove hair dye ,perming solution etc and they constantly leak should they put this kind of stuff into a macerator any ideas :?:
Macerators are meant for pumping toilet waste through small bore pipework not pumping waste water to a higher level. Perming solution is nasty stuff and is probably doing the seals in.
What is required is a waste pump rather than a macerator. It would be a good idea to check with the manufacturers about the compatibility with chemicals.
Mike
