Main 24 combi,con
26 Jan 2008
London
Hi ---- u ALL
Following this site with interest ever since i discovered it and now hooked--
Went to see above boiler------ Boiler is sited in the wall cabinet on 1st floor next to the bathroom--
Strange problem--whn HW demanded through the sink in the bath room Cold tap runs dry (ie pressure v.v.low)---whn CW from cold tap HW reduces pressure to a trickle
any suggestion with this would be a great help--
Some ideas
Is the whole house low pressure?
Stoptap not turned on enough
Valve under boiler again not opened enough
Blocked filter inside boiler
Limescale problem
A restriction could be anywhere from the cold mains in leading up to the tee on the hot between the two taps, perhaps an isolation valve not opened properly?
You are the man on the job. Shake a few brain cells and get looking.
thnx Slug ---- i was hoping u would reply--
shall follow up ---- and let you know the result---
