I had a problem with the pilot staying lit, cured it by cleaning the jet. But now the boiler doesn't fire-up when I turn the hot taps on. I havn't touched anything other than the pilot jet. Any tips would be appreciated.
I am an engineer, though not registered CORGI. Just trying to find out if it was something I could put right myself
What injector would that be.? .
Eh did you miss the bit where he said had cured pilot out by cleaning it
He had a problem with the pilot staying lit, probably thermocouple, he has now cleaned the the jet, he know can`t fire up the heater, I assume he is not a fitter and unused to servicing water heaters he has probably blocked the pilot injector, he know has two problems instead of his first problem. What do you think Sherlock?
good spilling
good spilling
Can`t spill if it don`t fire up idiot.
