Just installed a mixer shower which works with all hot water systems. Have installed a regulator valve on cold input into mixer to reduce flow, however hot water pressure is too low, so mains cold pressure over powers hot feed, so just a warm drizzle!!! Am looking at installing a 1.8bar single outlet pump for hot water. Would I need to put some inline regulator on the cold feed to balance the feed and bring the cold pressure down a bit, or will the pump be sufficient to boost pressure and solve the problem.
Any advice gratefully received.
Stewart
Stewart
