- Joined
- 11 Dec 2007
- Messages
- 400
- Reaction score
- 2
- Country
A few things i want to find out....
1) I mist coated the ceiling of the living room today. I went 1:1 paint:water. Dulux Supermatt. I know the tub says 1:3 wateraint but i went 1:1. It still seemed to cover the celing quite well though. Is this normal for a mist coat? I was expecting it to be very watery. It was to apply but i wasn't expecting much colour there once applied. It just seemed to cover it quite well. I didn't focus too much in one area either.
But on to more worrying things...
2) I splatted the walls, quite a bit in some sections, so i rubbed off this paint with a damp cloth as i wasn't yet ready to paint the walls. All was fine until i wiped one section & either side of where i've put a red X darkened up with the damp cloth but not this sweeping bit...
After it was damp i touched it & it was very sticky. I'm guessing probably the famous PVA?
I painted it with a brush & it seemed to cover ok (which i then wiped off). Whether it actually sticks to the plaster ok is another matter, but i wiped it off with the intention of coming here & seeing if i should prep it some way beforehand?
But then even where i have put filler had the same result & this didn't have PVA on top...
Then time was getting on so i did a small section & i was really surprised to see how the paint coverage turned out.
I've tried to find a before photo but i don't have any. There was nothing on this wall that indicated to me that any section of it would look different to any other section once painted, so that's why i was surprised to see this.......
What is that & why is it doing it?
Wall has been totally tanked using the K11 system. No salts or anything were forming on top. The plaster wasn't different in that section to the rest of the wall. It didn't feel colder than any of the rest of the wall.
This is only the first mist coat & who knows, subsequent coats may cover it. Though like everything else with this house, i doubt it. I just wondered why it looked like that, or a possible reason as to why?
