- Joined
- 27 Jan 2008
- Messages
- 23,948
- Reaction score
- 2,717
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
Histrionically this is incorrect, on the wall or front of car we have a spigot, on to this we fit the lamp, inside the lamp we could has a wick (oil) mantel (gas) or an element (electric) the latter is normally contained within a bulbous envelope of glass, or a bulb for short, there are exceptions, we also had tubes, so whole assembly is called a lamp, if you ask for a headlamp you will get the reflector and glass, but no bulb.Parlance correction, Lesson 1
Bulb![]()
Lamp![]()
Luminaire![]()
Aide memoire: Bulbs grow, lamps glow![]()
Today it is a bit of a problem, as the renewable item is often not bulbous, a coiled tube for example, and also the renewable item often contains more than the light emitting unit, it is common for ballasts, or drivers to be built inside the renewable unit, however the lighting trade tends to hang onto a name even when the name no longer describes what it is, so when the ballast is replaced with electronic components it is still called an electronic ballast, and a transformer again when replaced with electronic components is called an electronic transformer, and a device used to reduce the voltage for LED lamps is still called a driver even when it controls voltage not current, so in keeping with this trend, we still call the renewable part a bulb, when it replaces the bulbous part of yesteryear.
English is interesting in the way words have changed meanings, in this case the auto electrical trade have called a bulb a bulb all the way through, but the low voltage electrician has for years have spouted on how bulbs come from the garden, however they have failed to find a replacement word, Fitting, Luminaire, and Lamp, all refer to the whole unit.
The question on bulb size is interesting as well, it is all down to heat, so if we look at a gas or oil lamp, if it was to burn the fuel at a rate of 60 Joules per second likely the temperature would be far higher than a tungsten bulb burning the same amount of fuel, as the tungsten bulb emits more light, however if light is absorbed into a surface it is turned into heat, this is why we open and draw curtains over our windows, to stop or allow heat and light to enter or leave the house, so if you could get a 100W LED bulb as long as the light could pass through the shade it would run cooler than a 60W tungsten, so the limit for LED lamps would normally be higher than with a tungsten.
However I have stipulated a shade where the light can pass through it, if the shade defuses the light and does on allow all light to pass through it, then it could heat up the shade more with 60W of LED light than tungsten light as more light is being converted into heat. In real terms you can't get 60W LED bulbs so the problem does not arise.
Oddly I have returned to using a spigot in my mothers house, well modern equivalent to it, I can slide out the chandelier and replace any parts i.e. bulbs, then once all done, slide the hook, chain, and chandelier back in place, not that I do that, it is so I could fit rose to ceiling without needed to hold the weight then I had to support weight for very short time as the whole fitting is slid into place.
On my push bike I still have a spigot on the handle bars and a lamp which I slide into place as and when required. These
![il_340x270.1103841322_icpr.jpg](https://img0.etsystatic.com/162/0/11360695/il_340x270.1103841322_icpr.jpg)
