Hi guys.
My mates bathroom wasn't protected apart from an old fusebox (has LV downlights and a fan fitted by previous owners), so he introduced a 32mA MCB, in line with a double pole switch fused at 3A in between the main and the light transformers and fan.
You would think this would be straightforward enough however the damn MCB trips. It doesn't go immediately but between 5 and 60 seconds from resetting.
trying to help find the problem I have turned off the switch which is downstream of the MCB, isolating the lights and fan, and it still trips. Interestingly it also trips when the earth connections are removed from the back of the MCB, so I assume there must be some problem upstream in the ring between live and neutral??? Have treble-checked all connections from the ring though the MCB and switch...
any help or guidance welcomed. Note that this is on a spur off a 30A ring main not the lighting circuit. Maybe he would be better getting a sparks in to rewire it off a light circuit, as reading other similar problems sounds like some appliances on a ring can break down over time and cause problems ref insulation live to neutral, which I assume is the probable cause here?
