- Joined
- 23 Apr 2008
- Messages
- 41
- Reaction score
- 0
- Country
Hi - I have just purchased components to wire in a consumer unit in place of my old fuse box (ie CU box, 100A incomer switch, 80A RCD and 4xMCBs). However on 'dry' assembly, it seems that the wiring/busbar connection holes on the MCBs do not line up with the with the incomer or the RCD.
The MCBs and RCD are both VOLEX components and the incomer is an MK component. Additionally, the RC and incomer have misaligned holes also. (i.e I have three connection hole "levels")
What I would like to know is; Is this normal, and is it done to account for the busbar and connecting wires being fitted to the incomer and RCD or; should all the holes line up? If they should, is there any reason why the VOLEX components are not made to the same standard?
Before anyone panics, the final installation and connection to the meter wires will be done by an electrician - I am just trying to get the ground works done.
Any help would be greatly appreciated
Cheers
Jim
Cheers
Jim
