Megaflow Question
31 Aug 2012
Orkney
Hi all,
I have a question about my DHW, i have read through all the Megaflow instructions and cannot get an answer that i'm happy with?
Right i have the 210i Megaflow tank with a Danfoss CP715-si programmer.
I see in the megaflow instructions they mention the Danfoss TP9000? is this the unit that is supplied with it or have i been fitted with some cheaper alternative?
The reason i ask is the oil boiler never cuts out when the water is hot, just keeps on cycling. I read that a full tank should take around an hour to heat up, so after that the boiler should stop and only cut in again when water has lost heat or used?
Oil Boiler is Grant Vortex 21-26.
Not my first problem //www.diynot.com/forums/plumbing/central-heating-set-up-does-it-look-right.335704/
thanks for time, hopefully someone can help me out here!!
