Meriva Sun Roof
17 Jul 2012
Fife
I have an 06 plate Vauxhall Meriva Design with the twin sunroofs.The front one has stopped working. I'm guessing it's the motor. Can somebody tell me where the motor is located and/or if it could be something else causing it.
im only guessing but i would say in the boot area side panels. See if you can hear where exactly by operating the working sunroof.
Check all fuses are ok and maybe swap the switches over if they are the same, you may have to check for voltage at the motor terminals to confirm if its gone. Maybe its just seized up due to lack of use.
Thanks for the replies. Turns out it was the switch. All working now. Not that I need it!!
