Hello,
I would like to assistance to ascertain whether planning is/should be required in this instance.
Put simply:
Does the replacement of an existing stair access to a flat/s (which was technically non-complient) with a modern (complient) equivalent require planning permission? The flats have been in existance for decades (maybe 30 + years).
I can give many more details, but thought I would keep in simple at first.
It is a typical terraced row, businesses below and access the to flats via the rear. Some of which are accessed via metal, steep, fire escape type staircases. The stair cases are not visible except from the private access to the rear of the row.
General thoughts?
Many thanks in advance of any comments.
Put simply:
General thoughts?
