Hi
my c/h has stopped working but n/w is fine, i have tracked the probelm back the the mid valve, which is a drayton Ma1 actuator, which does not move when h/w is called for, i have managed to by pass the problem by manually operating the valve to the mid position untill i get a new one, however i just wanted to check with yourself, as there is only a few mm of movment within this valve, is this correct or is the actual valve faulty as well.
