My Miele T250C Novotronic Condenser Dryer has stopped functioning.
Initially it just stopped heating.
Following the advice on this forum i tested the thermostat 36FXH16 under the main back panel and deduced it was faulty. I ordered the spare and replaced.
But now whenever i turn the drier on, the buzzer comes on and stays on for about 20 seconds, the cool air light comes on, and the machine iron light flashes, regardless of what drying cycle is set.
After about 1 minute, the drier stops and then requires turning on and off in order for the control panel to be responsive again at all.
I have also cleaned every vent, filter etc and also cleared any dust from any PCB, connector i can see when i remove the top panel.
Anyone have any ideas?
EDIT: I also have just tested the rear NTC (short 2cm long brass probe in plastic case under the back panel) and there is continuity and less then 1ohm resistance. is this the prime suspect now?
