Mini LED's + Switch (unsure)
16 Jul 2006
Wales
Hello
I've bought these two items for my kitchen kickboards:
I understand switches in the simple sense, that is normally the live runs through the switch, but how do you fit a switch to the LED's transformer ?? Not Possible ??
The only other way I can think of, is to wire up the switch to a 1-gang socket and then plug the adaptor into that... It will work, but it seems inappropriate?
Cheers for any help & Merry Xmas
Your option to plug into a switched 13 amp socket is the best one.
Swtching the 12 volt output of the transformer would control the lights work BUT the ""transformer"" in the plug-top may not be designed to run continuously with its mains supply ON but its output disconnected.
It is also worth having the plug-top "transformer" in free air for cooling reasons.
Many thanks bernard for the reply and merry christmas :)
Will just use a socket on a switch then
Easy !!!
Do you mean a switched socket? Is there one in a sensible place?
Or are you planning to put a socket on the lighting circuit?
That worries me a tad...
Easy !!!
Hang on a minuite where are you feeding this from? and what precautions do you plan to take to ensure that parts are adequately protected against faults and overloading?
I was planning on doing this, as I cannot see another way... Needs a switch because socket (existing) is hard to get at (under worktops)
Not Wise ? :?: [/img]
It's not good is it :confused:
Or can I do that above without the mini-switch (just plug, cable and extra socket) because I can use the switch on the extra socket for convenience?
Thank you for any advice
Instead of the plug, socket and switch, install a fused spur, and feed the hidden socket from this.
Couldn't agree more. Can't stand seeing kitchen lighting (especially under pelmets) fed from a plug and flex, it looks a complete DIY botch.
Out of interest, what would be the correct way to wire this if you wanted them switched by a light switch, along with the rest of the lights in the kitchen, for example?
Others I've seen have the transformer on a lead, rather than a plug-top one. But if you do have a plug-top one, what's the best thing to do? Can you run say a 3A fused spur with a socket off a lighting circuit? Sounds a bit dodgy...
You should never put a socket on a lighting circuit :idea: - If it's there there's nothing to stop someone plugging something overrated into it..... ;)
When the appliance is used the ocpd trips and the lights go out.
It is poor design imo.
So...
