I have a classic mini. The hazzard lights don't work and because they don't work I can't find the relay as there is no ticking sound. The indicators work ok, any help please.
There is not enough information for any sort of reply.
You need to provide details. Year, model, trim level,then you may gat an answer.
I would personally get a Haynes ( others are available ) workshop manual and have a look at the wiring diagram for your car..
I had a 196? mini at one time... String pull downs to open the doors, Sliding windows that leaked profusely, and a starter button on the floor. And a gearbox from Hell operated by a 3 ft gear lever....
Anyone who had one will know what I mean...
That was lucky if it had any lights that worked at all...
Very common fault with these.
Its usually the little relay thats on the bulkhead under the bonnet, on the passenger side.
Try that, if that doesn't work, it might be the switch playing up.
IIRC there's also a seperate fuse for the hazards, its an inline fuse thats near the carb.
