I have a Mira 415 shower, the mixer block was replaced march 2009. When teh shower is off I get a random 'tapping' noise from inside the shower. there is no leaks. When I turn the water off at the stop cock or turn another hot tap on the sounds stops.
the other thing this could be if the pipes to the shower has been put through a stud in your wall and they didnt leave expansion room for the pipe so the pipe cant move it will make a tapping noice
