1. We are happy to announce the release of an iPhone/iPad app for DIYnot.
    Please read more...
    Dismiss Notice
Mira Shower dripping after water was turned off and on
Discussion in 'Plumbing and Central Heating' started by Patri1307, 13 Sep 2012.
  1. Patri1307
    11 Jun 2012
    4
    Thanks Received:
    London
    Country:
    I have a Mira Advance shower, which was working perfectly well, until I had a leak and had to turn the water off. Now it keeps dripping and is making strange noises, even when it has been turned off at the mains. Is this something easy to rectify or do I need to get Mira out?
    Thanks!
    P
  2. Performa
    17 Jun 2010
    52
    Thanks Received:
    Wolverhampton
    Country:
    Contact Mira if you're still in warranty and advise them you have no shut off.
    Sounds like your flow valve needs replacing.
    If your warranty has expired they do a fixed price repair too.
  3. vibrobullit407
    3 Feb 2012
    765
    Thanks Received:
    52
    Blackpool
    Country:
    Mira advance showers come with a 2 year warranty. If it's covered just ring them with the serial number and they will send out an engineer to fix the fault.
  4. Patri1307
    11 Jun 2012
    4
    Thanks Received:
    London
    Country:
    Thanks for your responses. I contacted Mira and I am no longer under warranty. :(
    Apparently, it is likely to be some rubble in the filter of the shower, which is hindering the shut off switch. So it needs to be taken apart and cleared, which apparently is an easy 10 minute job and not worth the call out charge for a Mira engineer.
Loading...
Share This Page
