Mira Sport Max - cold water after 5 minutes
p5x
3 Apr 2010
Not sure if you're familiar with this particular model but there's basically a on/off, high, medium, low light, overheat & low flow lights.
The high & on light are on (as would be expected) but none of the others, such as low flow/overheat. When the cold water comes on, none of the lights change but the shower starts making a weird humming noise.
If you turn it off, wait 20 secs and turn it back on, the hot water comes back on...but only for another few mins.
First thing to do is to open it up and inspect the internal wiring. It theres no loose bits or burnt bits, then open the switch on the ceiling/wall.
A burnt connection can manifest itself in the way you describe - intermittent power.
How old is it?
