Mira Sport Max Shower 10.8KW Low flow
6 Mar 2012
Guys,
Any help or troubleshooting advice appreciated.
Miramax Sport Max Power shower 10.8KW.
Last few days has stopped working
Low pressure light on when press HIGH or MED, no flow
no low pressure light on on LOW but still no flow.
I have read about checking water pressure but not sure how I can do that?
i.e. Water supply pipework or inlet filter restricted by a blockage or partial blockage - Flush supply pipe. Clean Inlet Filter.
Shower is 5 yrs old, and I have removed cover, checked and prodded, PCB etc
Power is on and back lights ok.
Steve
It likely to be a faulty element in the heating tank (there are two, three in most 10kw showers), you can check them with a multimeter.
You should have a reading of around 12>18 ohms.
If you have power to the elements and no heat it's probably the elements, no power to the elements then it's probably a microswitch.
Solenoid coils faulty.
Check the resistance with a multi meter, should be 3.4 kohms or above.
Test with power off.
Inlet filter would be my first port of call, it's held in by a black hexagonal plastic cap on the inlet. Turn the water supply off before you remove it or you'll get very wet.
Thanks muggles and Seco.
Ok, job done...and yes did check inlet filter was clean.
So ordered a new flow valve and solenoid from Mira...came next day. (£51)
Instructions a bit..iffy but managed to sort and change..took me 2hrs to get the main inlet feed into the unit and watertight (kept leaking)
word of advice..it's much easier if the PCB is pushed up and out of way!! do water inlet first, and then heater element feed...it's very fiddly. brute force does help a bit here.
Also..what's whats with the very small Hex keys...drove me mad...not a philips screw so had to go an buy a all in one Allan key to get what I needed.
Fingers crossed it stays fixed!
Thanks to all
Useally easier to just remove the unit for the sake of just undoing the mains cable and work on the unit on a table etc.
Torx T10 ;)
Yep...agreed..if I were a plumber and not a IT consultant I may have done that...lol....yes thats the one Torx T10
Sticking to IT...no water involved!! :)
Cheers
Steve
