MIRA SPRINT
1 Oct 2008
Hampshire
Hi, can anyone help, my Mira Sprint shower is taking longer and longer for the water to stop running after it has been turned off.
Does anyone have any ideas which part that my need replacing.
Thanks......Doug.
probabley the rubber o ring seals inside the valve are worn. if you have the model number usually the local plumbing merchants can supply you with a replacement kit. :)
mira sprint is an electric shower not a mixer valve.
check the solenoid valve may be getting lazy.
