leaking mira sprint sower
26 May 2010
Midlothian
Hi new to this , my mira sprint shower is leaking from the bottom ,i tried removing hose and checking the seal was still ok put hose back on but it is still leaking any ideas. :(
You need to take the cover off mate and have a look but make sure you turn off the electrics to the shower before doing this or get someone in who knows what they're doing.
thanks, have taken off cover and it appears to be leaking from a small black square box next to to on off switch.
New shower time then, sorry.
Just make sure you buy one with the same plumbing and electrical entry points and KW output or buy the same Mira shower if it's still a current model but give Mira a bell first to check!
01242262888
is it the early or late sprint ?
sounds like your talking about the flow valve.
why is it a new shower ? for the sake of changing a flow valve. 15min job.
Yes, Mira usually have good parts availability. Why spend £150 plus fitting for a new shower, if you can swap a cheap part?
Put a picture on here if you need help identifying the part, or there may be a diagram in the instruction book.
