Hello, I would be grateful for some advice from those with experience working in high rise flats.
The tenant currently has a bath mixer tap in a flat 11 floors up. Its one of those mixers with a lever in the middle that you pull up to switch to the shower function. They have a tank system, and the cold water cistern is probably only about 80 centimeters above the hot water cylinder. Now when they pull up the lever on mixer tap, it drops down as the pressure does not seem enough to hold it up.
That tap will need to be changed but could someone advise on a suitable tap? Pressurr is probably around 0.1 bar on hot bath tap. Would a deck mounted thermostatic bar shower mixer do the job? I have seen a couple which say suitable for 0.1 bar pressure
Thanks in advance
Thanks in advance
