mixer showers
8 Nov 2006
Bristol
I have a 100 litre hot water cylinder and a 25 gallon cold tank and have bought 2 mixer showers to install in seperate bathrooms, they will not be used at the same time. I was planning on fitting a single impeller pump and an equalising valve so i could use the hot cylinder off a surrey flange and cold from mains rather than the cold tank. Would that work and if i purchased a low powered pump, any ideas of possible showering time? Worried the cylinder isn't big enough..
It's heated from a heat only boiler.
the cylinders ok
but running a single pump on hot and mains pressure with a equalising valve.
easyer to run its own feed from a 50 gal cws tank and a twin pump.
Ordinarily i'd agree but there is no space for a 50 gallon. The hatch is one side, roof at the top and the central heating tanks are the other. Major work involved and questionable joist strength.
Any ideas on rough showering time and if the equalising valve idea will work?
hello mate running the cold mains fed not a problem running the impeller pump of the tank not a problem but you will be restricted to the time around 10-15 minutes max i should think have done this a few times and had customers complaining after but i did tell them first
it will work but not for long (timewise)
then you shouldn't of installed a pump running from a 25gal tank and suppling a cylinder.
you did tell them? so why do it then if its wrong, your their to advice.
should of been on a 50 gal tank min.
should of been on a 50 gal tank min.[/quote]
If the tank is a 25 and they wanted the pump fitted then that is their decision you cant completely change your whole house just for 1 thing sometimes you have to work with what there is, (like this guy is saying) he dont want to get into the relms of a bigger tank so he has to work with what he has.
so that means we'll break the water regs just cause we're lazy to link another tank.
all comes down to wanting the best but don't want to pay for it.
so we'll bend the rules and it won't matter.
people call in the pro's to do a proper job and advice them what can be done and what can't.
not just chuck it in and cross your fingers that all works and no one will know attitude.
you obviously don't follow water regs thats for sure.
thats if anyones got them.
i don't care what people have but least do it legal
Well the reason for wanting to use mains cold with an equaliser is due to tank size. I believe the pump will drain the tank fast. Maybe it is a better idea to link another 25gallon matching tank in. And put an overflow and a feed to the pump from there.
is it ok to leave the hot water cylinder cold feed where it is or move it?
Open to any ideas?
two 25gal tanks
linked together by 28mm pipe.
ballvalve on one tank
outlets on other tank.
cold feeds lower than cylinder feed.
