a mixer valve from the sheds ( Focus) is dripping how to remove the cartridges and spout(tried left and right pulling out of spout)?
Is it best to replace or try to repair?
if the valve is dripping you will need a overhaul seal repair kit.
if you don't have the model, make, etc you'll never be able to locate one.
as you say you got from a shed so 9/10 it will be some import garbage which they don't even stock now.
